nblade.notactivevscanserver events
nblade.notactivevscanserver EMS events occur when a connection from a remote IP is not found in the Vscan scanner pool belonging to the storage virtual machine (SVM).
Nblade.NotActiveVscanServer
- Severity
ERROR
- Description
This message occurs when a connection from a remote IP is not found in the Vscan scanner pool belonging to the storage virtual machine (SVM). Session setup request fails.
- Corrective Action
Investigate if the associated IPs need to be added to the active scanner pool.
- Syslog Message
CIFS connection on SVM %s (ID %u) from IP address %s fails to bind to an established Vscan related session because the IP address is not in the active scanner pool.
- Parameters
vserverName (STRING): Name of the SVM associated with this operation.
vsId (INT): ID of the SVM on which this event occurred.
remoteIpAddress (STRING): IP address of the client machine.
