ONTAP EMS reference
nblade.notactivevscanserver events
Nblade.NotActiveVscanServer
Severity
ERROR
This message occurs when a connection from a remote IP is not found in the Vscan scanner pool belonging to the storage virtual machine (SVM). Session setup request fails.
Corrective Action
Investigate if the associated IPs need to be added to the active scanner pool.
Syslog Message
CIFS connection on SVM %s (ID %u) from IP address %s fails to bind to an established Vscan related session because the IP address is not in the active scanner pool.
vserverName (STRING): Name of the SVM associated with this operation.
vsId (INT): ID of the SVM on which this event occurred.
remoteIpAddress (STRING): IP address of the client machine.
