raid.shared events
raid.shared.disk.awaiting.done
- Severity
INFORMATIONAL
- Description
This message occurs when a node receives an indication from its HA partner node that a shared disk is undergoing a change in state and the partner is waiting for the local node to complete a shared state transition.
- Corrective Action
(None).
- Syslog Message
Received shared disk awaiting done %s, state %s, substate 0x%lX, partner state %s, partner substate 0x%lX, partner dblade ID %s host type %d add details %s
- Parameters
disk_info (STRING): Formatted information of the shared disk.
local_state (STRING): State of the shared disk on the local node.
local_substate (LONGINTHEX): Sub-state of the shared disk on the local node.
partner_state (STRING): State of the shared disk on the partner node.
partner_substate (LONGINTHEX): Sub-state of the shared disk on the partner node.
received_ack (STRING): Dblade ID of node sending await done ack.
host_type (INT): Type of host node sending await done ack.
add_details (STRING): Additional details of the awaiting done event.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the disk vendor.
model (STRING): Model string of the disk.
firmware_revision (STRING): Disk firmware revision number.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.shared.disk.exchange
- Severity
INFORMATIONAL
- Description
This message occurs when a node receives an indication from its HA partner node that a shared disk is undergoing a change in state (e.g., disk is failing, going offline, or is getting unfailed). Accompanying EMS messages will indicate if any corrective action is required.
- Corrective Action
(None).
- Syslog Message
Received shared disk state exchange %s, event %s, state %s, substate 0x%lX, partner state %s, partner substate 0x%lX, failure reason %s, sick reason %s, offline reason %s, online reason %s, partner dblade ID %s, host %d %s
- Parameters
event (STRING): Describes the event which caused the partner to send this state exchange message. If this is a periodic exchange instead of an event triggered exchange, event is NONE.
failure_reason (STRING): Describes the error leading to the partner node failing the shared disk.
sick_reason (STRING): Describes the error leading to the partner node prefailing the shared disk.
offline_reason (STRING): Describes the reason the partner node is offlining the shared disk.
online_reason (STRING): Describes the reason the partner node is onlining the shared disk.
recv_reply (STRING): Describes the dblade ID of a partner node that sent a reply.
host_type (INT): Type of host sending the reply.
add_details (STRING): Additional partner node details of the shared disk state exchange.
timestamp (INT): Timestamp of the last on-disk state change.
