reg.cookie events
reg.cookie EMS events occur when allocation of cookies for traversing all keys under a prefix fails.
reg.cookie.null
- Severity
ERROR
- Description
This message occurs when allocation of cookies for traversing all keys under a prefix fails. An EFAULT error indicates that the cause is an empty registry tree. An ENOTSUPP error indicates that the prefix entered might not be supported on a vFiler unit. An ENOMEM error indicates that the system is running low on memory.
- Corrective Action
For an EFAULT error, check the prefix for spelling errors. For an ENOTSUPP error, try running the command on physical system, rather than a virtual system. For an ENOMEM error, close all applications that are consuming memory, as needed. If the problem persists,contact NetApp technical support
- Syslog Message
registry: Allocation of cookie for traversing all keys under the prefix %s, failed at function %s. Error number %d: %s.
- Parameters
location (STRING): Location in the registry code where the failure occurred.
prefix (STRING): Name of the prefix that was passed as an argument to the function.
errorno (INT): Internal error message number.
errormsg (STRING): Internal error message description.
