ONTAP EMS reference
se.gatherer events
se.gatherer.done
Severity
NOTICE
This message occurs when Single Instance Storage (SIS) auto gathering scanner completed on the auto adaptive volume.
Corrective Action
(None).
Syslog Message
Auto adaptive gathering scanner completed for %s %s %s %s %s.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
se.gatherer.skip
Severity
NOTICE
This message occurs when Single Instance Storage (SIS) auto adaptive gathering scanner could not be triggered on the volume post migration.
Corrective Action
Run "volume efficiency start" command with "-scan-old-data" to manually start the auto adaptive gathering scanner.
Syslog Message
Auto adaptive gathering scanner on volume %s%s could not be triggered for %s due to error: %s.
vol (STRING): Name of the volume
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
trigger_type (STRING): Type of the trigger that was attempted.
err (STRING): Error message that caused the failure.
