shelf.module events
shelf.module.configuration.failure
- Severity
ERROR
- Description
This message occurs when the system cannot complete the configuration of a disk shelf module with the desired parameters.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Could not complete the configuration of disk shelf module %s on channels %s, disk shelf ID %d.
- Parameters
element (STRING): Disk shelf module designator (A is the upper module, B is the lower module).
channels (STRING): Channels that have the error if local, PARTNER for high-availibility partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID of the disk shelf.
shelf.module.element.missing
- Severity
ALERT
- Description
This message occurs when an element is missing, unused, or disconnected.
- Corrective Action
Verify that both disk shelf modules are fully seated and locked in place. Also make sure that they are of the same product family.
- Syslog Message
Disk shelf module %s is MISSING on channels %s disk shelf ID %d.
- Parameters
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID of the disk shelf reporting the error.
