ONTAP EMS reference
shelf.module events
shelf.module.configuration.failure
Severity
ERROR
This message occurs when the system cannot complete the configuration of a disk shelf module with the desired parameters.
Corrective Action
Contact NetApp technical support.
Syslog Message
Could not complete the configuration of disk shelf module %s on channels %s, disk shelf ID %d.
element (STRING): Disk shelf module designator (A is the upper module, B is the lower module).
channels (STRING): Channels that have the error if local, PARTNER for high-availibility partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID of the disk shelf.
shelf.module.element.missing
Severity
ALERT
This message occurs when an element is missing, unused, or disconnected.
Corrective Action
Verify that both disk shelf modules are fully seated and locked in place. Also make sure that they are of the same product family.
Syslog Message
Disk shelf module %s is MISSING on channels %s disk shelf ID %d.
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID of the disk shelf reporting the error.
