ONTAP EMS reference
sis.enable events
sis.enable EMS events occur when ONTAP encounters issues associated with storage efficiency feature enablement.
sis.enable.post.sm.break
Severity
NOTICE
This message occurs when the "storage efficiency" feature is enabled on a destination volume due to a broken SnapMirror® relationship on an All Flash Optimized system. When the relationship breaks, the DP volume is converted to RW, and all RW volumes have the "storage efficiency" feature enabled.
Corrective Action
(None).
Syslog Message
"Storage efficiency" feature has been enabled on the destination volume %s due to a SnapMirror break operation.
volume (STRING): Destination FlexVol® volume name on which the "storage efficiency" feature is enabled.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
sis.enable.post.ssm.init
Severity
NOTICE
This message occurs when the "storage efficiency" feature is enabled on a destination volume with Synchronous SnapMirror® on an All Flash Optimized system.
Corrective Action
(None).
Syslog Message
"Storage efficiency" feature has been enabled on the destination volume %s after Asynchronous Snapmirror converted to Synchronous Snapmirror.
