sis.enable events
sis.enable EMS events occur when ONTAP encounters issues associated with storage efficiency feature enablement.
sis.enable.post.sm.break
- Severity
NOTICE
- Description
This message occurs when the "storage efficiency" feature is enabled on a destination volume due to a broken SnapMirror® relationship on an All Flash Optimized system. When the relationship breaks, the DP volume is converted to RW, and all RW volumes have the "storage efficiency" feature enabled.
- Corrective Action
(None).
- Syslog Message
"Storage efficiency" feature has been enabled on the destination volume %s due to a SnapMirror break operation.
- Parameters
volume (STRING): Destination FlexVol® volume name on which the "storage efficiency" feature is enabled.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
sis.enable.post.ssm.init
- Severity
NOTICE
- Description
This message occurs when the "storage efficiency" feature is enabled on a destination volume with Synchronous SnapMirror® on an All Flash Optimized system.
- Corrective Action
(None).
- Syslog Message
"Storage efficiency" feature has been enabled on the destination volume %s after Asynchronous Snapmirror converted to Synchronous Snapmirror.
- Parameters
