sis.upgrademetafile events
sis.upgrademetafile.failed
Severity
ERROR
This message occurs when Single Instance Storage (SIS) metafiles cannot be created during a Data ONTAP® upgrade. The 'sis status' command will not display this volume. SIS operations cannot be triggered manually or according to a schedule for the volume.
Corrective Action
Correct the underlying issue indicated by the error message, and then run 'sis on' command to trigger the SIS upgrade again. If the upgrade succeeds, SIS then resumes normally.
Syslog Message
Could not create the metafiles for the volume %s%s: %s.
vol (STRING): Path to the volume.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
err (STRING): Reason for the failure.
