vs.migrate events
vs.migrate EMS events occur when ONTAP encounters issues associated with Vserver migration operations.
vs.migrate.cleanup.completed
- Severity
NOTICE
- Description
This message occurs when the source Vserver cleanup operation has completed.
- Corrective Action
(None).
- Syslog Message
Migrate source Vserver cleanup completed for Vserver: %s.
- Parameters
vserver_name (STRING): Name of the Vserver.
migration_uuid (STRING): Migration UUID.
vs.migrate.complete
- Severity
NOTICE
- Description
This message occurs when migrate operation completed.
- Corrective Action
(None).
- Syslog Message
Migrate of Vserver:%s has completed.
- Parameters
vs.migrate.cutover.commit.started
- Severity
NOTICE
- Description
This message occurs when migrate cutover commit started successfully.
- Corrective Action
(None).
- Syslog Message
Migrate cutover has started for Vserver:%s.
- Parameters
vs.migrate.cutover.completed
- Severity
NOTICE
- Description
This message occurs when migrate cutover operation completed.
- Corrective Action
(None).
- Syslog Message
Migrate cutover has completed for Vserver:%s.
- Parameters
vs.migrate.cutover.precommit.started
- Severity
NOTICE
- Description
This message occurs when the migrate operation has started the precommit for cutover.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.cutover.triggered
- Severity
NOTICE
- Description
This message occurs when cutover is triggered on a Vserver that is migrating.
- Corrective Action
(None).
- Syslog Message
Cutover was triggered on a migrating Vserver:%s.
- Parameters
vs.migrate.dst.ponr.updated
- Severity
NOTICE
- Description
This message occurs when the vserver migrate cutover workflow has reached and updated the point of no return (PONR) on the destination cluster.
- Corrective Action
(None).
- Syslog Message
Point of no return on destination Vserver %s has been updated successfully.
- Parameters
vs.migrate.failed
- Severity
ERROR
- Description
This message occurs when the Vserver migrate operation fails.This can occur before/during cutover or during post cutover activity. If failure is before/during cutover then source Vserver is in still operational and if migrate fails during post cutover activity then destination vserver is up. Once migrate issues are fixed, migrate can be resumed back to its origional state.
- Corrective Action
Run the "vserver migrate show -fields status-details" to view the error and follow the corrective action recommended.
- Syslog Message
Migration of Vserver "%s" Failed.
- Parameters
vserver_name (STRING): Vserver name.
err_status (STRING): Reason for the migrate operation failure and the corrective action to fix the problem.
vs.migrate.pause.complete
- Severity
NOTICE
- Description
This message occurs when the migrate operation for a Vserver is paused.
- Corrective Action
(None).
- Syslog Message
Migrate of Vserver:%s was paused.
- Parameters
vs.migrate.precheck.completed
- Severity
NOTICE
- Description
This message occurs when the migrate operation has completed the prechecks.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
sourceCluster (STRING): Name of the source cluster.
destinationCluster (STRING): Name of the destination cluster.
vs.migrate.precheck.failed
- Severity
ERROR
- Description
This message occurs when the migrate operation has failed the prechecks.
- Corrective Action
Run the "vserver migrate show" command to view the description of the error and the corrective action.
- Syslog Message
(None).
- Parameters
err_status (STRING): Reason for the precheck operation failure and the corrective action to fix the problem.
vs.migrate.precheck.started
- Severity
NOTICE
- Description
This message occurs when the migrate operation has started the prechecks.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.readyforcutover
- Severity
NOTICE
- Description
This message occurs when the migrate operation has reached the ready-for-cutover state.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.resume
- Severity
NOTICE
- Description
This message occurs when the migrate operation for a Vserver is resumed after an abort or a failure.
- Corrective Action
(None).
- Syslog Message
Migrate of Vserver:%s was resumed.
- Parameters
vs.migrate.rolledback
- Severity
NOTICE
- Description
This message occurs when Vserver migrate operation moves back from ready-to-cutover to transferring state after cutover was triggerred. This can be due to high transfer duration or due to some failure that might have occured when cutover was triggered on destination cluster.
- Corrective Action
(None).
- Syslog Message
Migrate state for Vserver %s was rolled back to transferring. Run "vserver migrate show -fields status-details" to see the reason for rollback. If the rollback is due to high transfer duration, reduce the I/O operations at the migrate source cluster to a lower rate.
- Parameters
vs.migrate.src.abort.completed
- Severity
NOTICE
- Description
This message occurs when the Vserver migrate abort operation on the source cluster has completed.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.src.abort.failed
- Severity
ERROR
- Description
This message occurs when the Vserver abort operation on the source cluster has failed.
- Corrective Action
Run the "vserver migrate show -fields status-details" command to view the description of the error and the corrective action.
- Syslog Message
Vserver migrate abort operation failed for Vserver: %s. Error: %s
- Parameters
err_status (STRING): Reason for the abort operation failure and the corrective action to fix the problem.
vs.migrate.src.cleanup.failed
- Severity
ERROR
- Description
This message occurs when the source Vserver cleanup operation fails.
- Corrective Action
- Syslog Message
Migrate source Vserver cleanup failed for Vserver: %s.
- Parameters
err_status (STRING): Reason for the source cleanup operation failure and the corrective action to fix the problem.
vs.migrate.src.cleanup.started
- Severity
NOTICE
- Description
This message occurs when the source Vserver cleanup operation starts. This operation starts only after the Vserver user data and configuration metadata have been replicated to the destination cluster, and the destination Vserver is serving data. This cleanup operation eventually deletes the source Vserver.
- Corrective Action
(None).
- Syslog Message
Migrate source Vserver cleanup started for Vserver: %s.
- Parameters
vs.migrate.src.ponr.failed
- Severity
ERROR
- Description
This message occurs when the vserver migrate cutover workflow has failed to reach and update the point of no return (PONR).
- Corrective Action
Run "vserver migrate show -instance" at the source cluster. If the point of no return is set to true, run "vserver migrate restart" command at the migrate destination cluster to start the destination Vserver. If the point of no return is set to false and the source Vserver is in a stopped state, run "Vserver start" at the source cluster to start the Vserver.
- Syslog Message
Failed to update point of no return for Vserver %s.
- Parameters
vserver_name (STRING): Vserver Name.
err_status (STRING): Reason for the ponr operation failure and the corrective action to fix the problem.
vs.migrate.src.ponr.updated
- Severity
NOTICE
- Description
This message occurs when the vserver migrate cutover workflow has reached and updated the point of no return (PONR) on the source cluster.
- Corrective Action
(None).
- Syslog Message
Point of no return on source Vserver %s has been updated successfully.
- Parameters
vs.migrate.start
- Severity
NOTICE
- Description
This message occurs when the migrate operation for Vserver from source cluster to destination cluster starts.
- Corrective Action
(None).
- Syslog Message
Migrate of Vserver:%s started from source cluster:%s to destination cluster:%s.
- Parameters
vs.migrate.sync.reached
- Severity
NOTICE
- Description
This message occurs when the migrate operation has reached sync.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.transferring.completed
- Severity
NOTICE
- Description
This message occurs when the migrate operation has completed the transferring operation.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vs.migrate.transferring.started
- Severity
NOTICE
- Description
This message occurs when the migrate operation has started transferring successfully.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
