ONTAP EMS reference
vs.migrate events
vs.migrate EMS events occur when ONTAP encounters issues associated with Vserver migration operations.
vs.migrate.cleanup.completed
Severity
NOTICE
This message occurs when the source Vserver cleanup operation has completed.
Corrective Action
(None).
Syslog Message
Migrate source Vserver cleanup completed for Vserver: %s.
vserver_name (STRING): Name of the Vserver.
migration_uuid (STRING): Migration UUID.
vs.migrate.complete
Severity
NOTICE
This message occurs when migrate operation completed.
Corrective Action
(None).
Syslog Message
Migrate of Vserver:%s has completed.
vs.migrate.cutover.commit.started
Severity
NOTICE
This message occurs when migrate cutover commit started successfully.
Corrective Action
(None).
Syslog Message
Migrate cutover has started for Vserver:%s.
vs.migrate.cutover.completed
Severity
NOTICE
This message occurs when migrate cutover operation completed.
Corrective Action
(None).
Syslog Message
Migrate cutover has completed for Vserver:%s.
vs.migrate.cutover.precommit.started
Severity
NOTICE
This message occurs when the migrate operation has started the precommit for cutover.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.cutover.triggered
Severity
NOTICE
This message occurs when cutover is triggered on a Vserver that is migrating.
Corrective Action
(None).
Syslog Message
Cutover was triggered on a migrating Vserver:%s.
vs.migrate.dst.ponr.updated
Severity
NOTICE
This message occurs when the vserver migrate cutover workflow has reached and updated the point of no return (PONR) on the destination cluster.
Corrective Action
(None).
Syslog Message
Point of no return on destination Vserver %s has been updated successfully.
vs.migrate.failed
Severity
ERROR
This message occurs when the Vserver migrate operation fails. This can occur before/during cutover or during post cutover activity. If the failure occurs before or during cutover then the source Vserver will still be operational. If the failure occurs during post cutover activity then the destination Vserver will be operational. Once the migrate issues are fixed, the migrate operation can be resumed from its prior state.
Corrective Action
Run the "vserver migrate show -fields status-details" to view the error and follow the corrective action recommended.
Syslog Message
Migration of Vserver "%s" Failed.
vserver_name (STRING): Vserver name.
err_status (STRING): Reason for the migrate operation failure and the corrective action to fix the problem.
vs.migrate.pause.complete
Severity
NOTICE
This message occurs when the migrate operation for a Vserver is paused.
Corrective Action
(None).
Syslog Message
Migrate of Vserver:%s was paused.
vs.migrate.postcutover.patch.adjustment
Severity
NOTICE
This message occurs when the attributes of a volume on the migrate destination cannot be patched to exactly match its attributes on the source post cutover. Rather than leave the volume unpatched, the system adjusts the attributes to the best possible values. For example, if the volume is almost full at cutover, it may grow slightly before the patching can take place. In this case, the system will patch the attributes to reflect the new size instead of the size on the source.
Corrective Action
Run the "vserver migrate show -fields status-details" command to view the particular changes made by the system. In most cases, no corrective action is required.
Syslog Message
(None).
volume_name (STRING): Name of the volume.
vs.migrate.precheck.completed
Severity
NOTICE
This message occurs when the migrate operation has completed the prechecks.
Corrective Action
(None).
Syslog Message
(None).
sourceCluster (STRING): Name of the source cluster.
destinationCluster (STRING): Name of the destination cluster.
vs.migrate.precheck.failed
Severity
ERROR
This message occurs when the migrate operation has failed the prechecks.
Corrective Action
Run the "vserver migrate show" command to view the description of the error and the corrective action.
Syslog Message
(None).
err_status (STRING): Reason for the precheck operation failure and the corrective action to fix the problem.
vs.migrate.precheck.started
Severity
NOTICE
This message occurs when the migrate operation has started the prechecks.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.readyforcutover
Severity
NOTICE
This message occurs when the migrate operation has reached the ready-for-cutover state.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.resume
Severity
NOTICE
This message occurs when the migrate operation for a Vserver is resumed after an abort or a failure.
Corrective Action
(None).
Syslog Message
Migrate of Vserver:%s was resumed.
vs.migrate.rolledback
Severity
NOTICE
This message occurs when a Vserver migrate operation rolls back to the transferring state from the transferring, ready-for-cutover, cutover-triggered, or cutover-started state (assuming the point of no return has not been reached). A rollback can be caused by high transfer duration or some other failure while in one of these states.
Corrective Action
(None).
Syslog Message
Migrate state for Vserver %s was rolled back to transferring. Run "vserver migrate show -fields status-details" to see the reason for rollback. If the rollback was due to high transfer duration, reduce the I/O operations at the migrate source cluster to a lower rate.
vs.migrate.src.abort.completed
Severity
NOTICE
This message occurs when the Vserver migrate abort operation on the source cluster has completed.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.src.abort.failed
Severity
ERROR
This message occurs when the Vserver abort operation on the source cluster has failed.
Corrective Action
Run the "vserver migrate show -fields status-details" command to view the description of the error and the corrective action.
Syslog Message
Vserver migrate abort operation failed for Vserver: %s. Error: %s
err_status (STRING): Reason for the abort operation failure and the corrective action to fix the problem.
vs.migrate.src.cleanup.failed
Severity
ERROR
This message occurs when the source Vserver cleanup operation fails.
Corrective Action
Syslog Message
Migrate source Vserver cleanup failed for Vserver: %s.
err_status (STRING): Reason for the source cleanup operation failure and the corrective action to fix the problem.
vs.migrate.src.cleanup.started
Severity
NOTICE
This message occurs when the source Vserver cleanup operation starts. This operation starts only after the Vserver user data and configuration metadata have been replicated to the destination cluster, and the destination Vserver is serving data. This cleanup operation eventually deletes the source Vserver.
Corrective Action
(None).
Syslog Message
Migrate source Vserver cleanup started for Vserver: %s.
vs.migrate.src.ponr.failed
Severity
ERROR
This message occurs when the vserver migrate cutover workflow has failed to reach and update the point of no return (PONR).
Corrective Action
Run "vserver migrate show -instance" at the source cluster. If the point of no return is set to true, run "vserver migrate restart" command at the migrate destination cluster to start the destination Vserver. If the point of no return is set to false and the source Vserver is in a stopped state, run "Vserver start" at the source cluster to start the Vserver.
Syslog Message
Failed to update point of no return for Vserver %s.
vserver_name (STRING): Vserver Name.
err_status (STRING): Reason for the ponr operation failure and the corrective action to fix the problem.
vs.migrate.src.ponr.updated
Severity
NOTICE
This message occurs when the vserver migrate cutover workflow has reached and updated the point of no return (PONR) on the source cluster.
Corrective Action
(None).
Syslog Message
Point of no return on source Vserver %s has been updated successfully.
vs.migrate.start
Severity
NOTICE
This message occurs when the migrate operation for Vserver from source cluster to destination cluster starts.
Corrective Action
(None).
Syslog Message
Migrate of Vserver:%s started from source cluster:%s to destination cluster:%s.
vs.migrate.sync.reached
Severity
NOTICE
This message occurs when the migrate operation has reached sync.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.transferring.completed
Severity
NOTICE
This message occurs when the migrate operation has completed the transferring operation.
Corrective Action
(None).
Syslog Message
(None).
vs.migrate.transferring.started
Severity
NOTICE
This message occurs when the migrate operation has started transferring successfully.
Corrective Action
(None).
Syslog Message
(None).
