vsdr.missing events
vsdr.missing.clone.parent.volume
- Severity
ERROR
 - Description
This message occurs when the clone parent volume does not exist during the Vserver SnapMirror®/MetroCluster(tm) baseline replication on the secondary site. Vserver SnapMirror/MetroCluster replication will be blocked until this problem is resolved, and delaying action on this problem will lead to inconsistent data on the primary and secondary sites.
 - Corrective Action
Use the (privilege: diag) "debug vreport show -type volume" command on the primary site to show the list of inconsistent volumes. For each of these inconsistent volumes, use the (privilege: diag) "debug vreport fix -type volume" command to resolve all of the issues on the Vserver SnapMirror/MetroCluster primary site. After the above problem is resolved, run the "snapmirror resync/metrocluster vserver resync" command.
 - Syslog Message
Parent volume for clone volume %s:%s is missing.
 - Parameters
vserver (STRING): Name of the Vserver.
volume (STRING): Name of the clone volume for which the corresponding parent volume is missing.
