ONTAP EMS reference
wafl.shutdown events
wafl.shutdown EMS events occur during shutdown, to indicate that a volume has not been marked clean.
wafl.shutdown.notClean
Severity
NOTICE
This message occurs during shutdown, to indicate that a volume has not been marked clean. By itself, this is not necessarily a problem. When this event occurs in conjunction with WAFL inconsistency panics or higher-severity EMS events, this message can indicate a potential source of the inconsistencies.
Corrective Action
No immediate action is required. If this message occurs in conjunction with WAFL inconsistency panics or other EMS messages, contact NetApp technical support.
Syslog Message
%s %s%s%s%s not marked clean (volume state is %s).
type (STRING): Type of object (volume/aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
state (STRING): State of the volume.
