ONTAP EMS reference
wafl.stream events
wafl.stream.check.complete
Severity
NOTICE
This message occurs when the "wafl scan stream_check" command is completed successfully.
Corrective Action
(None).
Syslog Message
"wafl scan stream_check" command successfully completed on volume "%s:%s". The total number of invalid stream files detected is %u.
volume (STRING): Volume name.
vserver_uuid (STRING): Universal Unique ID (UUID) of the volume's SVM.
total (INT): Total number of invalid stream files detected.
wafl.stream.check.invalid.file
Severity
ERROR
This message occurs when the "wafl scan stream_check" command detects a stream file with the name "." or "..". Files with these names are not allowed. If you have files with these names, you might be unable to access these files.
Corrective Action
Manually delete the base file which in turn will also delete the invalid stream file.
Syslog Message
Detected invalid stream file associated with base file inode "%d" on volume "%s:%s".
fileId (INT): The base file inode number that has a stream file with the name "." or "..".
wafl.stream.check.start
Severity
NOTICE
This message occurs when the "wafl scan stream_check" command is started.
Corrective Action
(None).
Syslog Message
"wafl scan stream_check" command successfully started on volume "%s:%s".
