wafl.stream events
wafl.stream EMS events occur when ONTAP encounters issues associated with stream file validation operations.
wafl.stream.check.complete
- Severity
NOTICE
- Description
This message occurs when the "wafl scan stream_check" command is completed successfully.
- Corrective Action
(None).
- Syslog Message
"wafl scan stream_check" command successfully completed on volume "%s:%s". The total number of invalid stream files detected is %u.
- Parameters
volume (STRING): Volume name.
vserver_uuid (STRING): Universal Unique ID (UUID) of the volume's SVM.
total (INT): Total number of invalid stream files detected.
wafl.stream.check.invalid.file
- Severity
ERROR
- Description
This message occurs when the "wafl scan stream_check" command detects a stream file with the name "." or "..". Files with these names are not allowed. If you have files with these names, you might be unable to access these files.
- Corrective Action
Manually delete the base file which in turn will also delete the invalid stream file.
- Syslog Message
Detected invalid stream file associated with base file inode "%d" on volume "%s:%s".
- Parameters
fileId (INT): The base file inode number that has a stream file with the name "." or "..".
wafl.stream.check.start
- Severity
NOTICE
- Description
This message occurs when the "wafl scan stream_check" command is started.
- Corrective Action
(None).
- Syslog Message
"wafl scan stream_check" command successfully started on volume "%s:%s".
- Parameters
