ONTAP EMS reference
cf.diskinventory events
cf.diskinventory.cksum.fail
Severity
ALERT
This message occurs when the computed checksum of the disk inventory message is different from the checksum sent as part of the disk inventory message.
Corrective Action
(None).
Syslog Message
Disk inventory checksum mismatch: old %d new %d.
oldCkSum (INT): Old checksum, sent as part of the message.
newCkSum (INT): Checksum of the disk inventory message computed locally.
cf.diskinventory.many.disks
Severity
INFORMATIONAL
This message occurs when a node receives more than maximum supported disks in the disk inventory message.
Corrective Action
(None).
Syslog Message
disk inventory: ndisks %d max_disks %d
ndisks (INT): Number of disk descriptions sent in the inventory message.
maxdisks (INT): Maximum number of disks supported.
