ONTAP EMS reference
cf.rsrc events
cf.rsrc EMS events occur when ONTAP encounters issues associated with resource management during takeover and giveback operations.
cf.rsrc.givebackFail
Severity
ALERT
This message occurs when a failure is detected during giveback. The giveback operation will be cancelled.
Corrective Action
Check the logs for other messages regarding the listed subsystem using the "event log show" CLI command. Resolve those problems and perform a planned giveback operation using "storage failover giveback" command.
Syslog Message
Failover monitor: giveback during %s failed; giveback cancelled.
op (STRING): Name of the giveback subsystem that has suffered a fatal error.
cf.rsrc.givebackForceFail
Severity
ERROR
This event occurs if a failure is forced during giveback. This event should only occur in debugging kernels.
Corrective Action
Retry the takeover.
Syslog Message
Failover monitor: giveback during %s forced fail
op (STRING): Name of the takeover operation
cf.rsrc.givebackForceVeto
Severity
ERROR
This event occurs if a veto is forced during giveback. This event should only occur in debugging kernels.
Corrective Action
Check the state of the subsystem listed in this message. Retry the giveback.
Syslog Message
Giveback during %s forced veto
cf.rsrc.givebackOpFail
Severity
ERROR
This event occurs if a failure is detected during giveback. This error is not fatal to the giveback process but indicates that the related service could not be shutdown cleanly.
Corrective Action
Check the state of the subsystem listed in the message and validate it is working correctly. Validate that there are no configuration errors for the listed subsystem.
Syslog Message
Failover monitor: giveback during %s failed; giveback continuing…​
op (STRING): Name of the giveback operation that has suffered a non-fatal error.
cf.rsrc.givebackUnexpected
Severity
ALERT
This event occurs if we detect an unexpected failover monitor state during a giveback operation. This indicates a software bug.
Corrective Action
Retry the giveback.
Syslog Message
(None).
state (INT): Value of the failover monitor state
cf.rsrc.givebackVeto
Severity
ALERT
This message occurs when a veto is indicated during giveback. A veto occurs when the active partner state is detected during the giveback process. A veto can be overridden by using the "cf giveback -f" or "storage failover takeover -override-vetoes true" command.
Corrective Action
Check the preceeding messages for reasons why the giveback was vetoed. Check the state of the subsystem listed in this message. Retry the giveback.
Syslog Message
Failover monitor: %s: giveback canceled due to active state.
op (STRING): Name of the takeover operation.
cf.rsrc.raidReplayOnlyTODone
Severity
INFORMATIONAL
This event occurs when a node is booting after having panicked too soon after takeover or during takeover. In that event we want to replay the partner RAID logs, before we perform a giveback. This message indicates the point at which we have committed partner RAID logs to the disk and are now going to initiate a giveback.
Corrective Action
(None).
Syslog Message
Failover monitor: Raid replay-only takeover completed. Initiating giveback.
(None).
cf.rsrc.replayOnlyTakeoverDone
Severity
NOTICE
This event occurs when a node is booting after having panicked too soon after takeover or during takeover. In that event we want to replay the partner logs, before we perform a giveback. This message indicates the point at which we have committed partner logs to the disk and are now going to initiate a giveback.
Corrective Action
(None).
Syslog Message
Failover monitor: replay-only takeover completed. Initiating giveback.
(None).
cf.rsrc.takeoverFail
Severity
ALERT
This message occurs when a failure is detected during takeover. The takeover operation will be cancelled.
Corrective Action
Contact NetApp technical support.
Syslog Message
Failover monitor: takeover during %s failed; takeover cancelled.
op (STRING): Name of the takeover operation that has suffered a fatal error.
cf.rsrc.takeoverForceFail
Severity
ERROR
This event occurs if a failure is forced during takeover. This event should only occur in debugging kernels.
Corrective Action
Retry the takeover request.
Syslog Message
Failover monitor: takeover during %s forced fail
cf.rsrc.takeoverOpFail
Severity
ERROR
This event occurs if a failure is detected during takeover. This error is not fatal to the takeover process but indicates that the related service may be inaccessible during takeover of the partner.
Corrective Action
After takeover completes, check the state of the subsystem listed in the message. Check that the configuration of the subsystem listed in the messsage is correct.
Syslog Message
Failover monitor: takeover during %s failed; takeover continuing…​
op (STRING): Name of the takeover operation that has suffered a non-fatal error.
cf.rsrc.takeoverUnexpected
Severity
ERROR
This event occurs if we detect an unexpected failover monitor state during a takeover operation. This indicates a software bug.
Corrective Action
Check the state of the subsystem listed in 'op' parameter. Retry the giveback.
Syslog Message
(None).
