ONTAP EMS reference
cifs.lug events
cifs.lug.import.fail
Severity
ERROR
This message occurs when the job to import CIFS local users and groups is completed successfully only at a primary site within a MetroCluster® configuration or Vserver DR setup. CIFS local users and groups have either not been applied or only partially applied at the secondary site.
Corrective Action
Use the "metrocluster vserver resync -vserver <vserver name>" command to resynchronize the Vserver configuration.
Syslog Message
CIFS local users and groups import job failed for Vserver %s. Reason: %s.
vserver (STRING): Name of the Vserver.
reason (STRING): Reason for the failure.
