cifs.lug events
cifs.lug EMS events occur when the job to import CIFS local users and groups is completed successfully only at a primary site within a MetroCluster® configuration or Vserver DR setup.
cifs.lug.import.fail
- Severity
ERROR
- Description
This message occurs when the job to import CIFS local users and groups is completed successfully only at a primary site within a MetroCluster® configuration or Vserver DR setup. CIFS local users and groups have either not been applied or only partially applied at the secondary site.
- Corrective Action
Use the "metrocluster vserver resync -vserver <vserver name>" command to resynchronize the Vserver configuration.
- Syslog Message
CIFS local users and groups import job failed for Vserver %s. Reason: %s.
- Parameters
vserver (STRING): Name of the Vserver.
reason (STRING): Reason for the failure.
