ONTAP EMS reference
clam.disable events
clam.disable EMS events occur when ONTAP encounters issues associated with Connectivity, Liveliness, Availability Monitor (CLAM) being disabled.
clam.disable
Severity
INFORMATIONAL
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) is disabled by either turning off the KCS capability or by setting the 'clam sysctl/bootarg' variable.
Corrective Action
If you want CLAM functionality disabled, no action is needed. Otherwise, reenable CLAM and reboot the node to make CLAM operational again.
Syslog Message
CLAM functionality is disabled.
(None).
clam.disable.takeover
Severity
INFORMATIONAL
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) is disabled from initiating storage failover requests. This capability is automatically disabled in a NAS-only configuration. To control the setting of CLAM takeover, additional interfaces, such as sysctl bootarg, are provided.
Corrective Action
No action is needed.
Syslog Message
CLAM is disabled from performing storage failover.
(None).
