ONTAP EMS reference
clam.failover events
clam.failover EMS events occur when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) receives a failover event from high-availability(HA) subsystem.
clam.failover.event
Severity
INFORMATIONAL
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) receives a failover event from high-availability(HA) subsystem.
Corrective Action
(None).
Syslog Message
CLAM on node (id=%llu) received an HA failover event for partner (ID=%llu) indicating that %s.
localnodeid (LONGINT): Node ID of the local node.
partnernodeid (LONGINT): Node ID of the partner node.
event_description (STRING): Description of the event that CLAM received from the HA subsystem.
