cloud.secddnserror events
cloud.secddnserror EMS events occur when this ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint.
cloud.SecdDNSError
- Severity
ERROR
- Description
This message occurs when this ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint.
- Corrective Action
Verify that DNS/SECD is set up correctly on this ONTAP Cloud instance and fix it if not.
- Syslog Message
This ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint "%s".
- Parameters
db_endpoint (STRING): Name of the cloud database endpoint associated with this ONTAP Cloud instance.
