ONTAP EMS reference
cloud.secddnserror events
cloud.secddnserror EMS events occur when this ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint.
cloud.SecdDNSError
Severity
ERROR
This message occurs when this ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint.
Corrective Action
Verify that DNS/SECD is set up correctly on this ONTAP Cloud instance and fix it if not.
Syslog Message
This ONTAP Cloud instance fails to communicate with DNS/SECD for the cloud database endpoint "%s".
db_endpoint (STRING): Name of the cloud database endpoint associated with this ONTAP Cloud instance.
