ONTAP EMS reference
clus.net events
clus.net.noNeighbors
Severity
ALERT
This message occurs when the cluster network ports with "link" reported as "up" are neither receiving CDP nor LLDP neighbor announcements. This is not a supported configuration and can negatively impact the performance of the cluster.
Corrective Action
Use the "network port show -ipspace Cluster -link up" command to list the ports expected to receive CDP and/or LLDP announcements. Verify that CDP and/or LLDP is enabled on the switch the cluster ports are wired to. Use the "network device-discovery show" command to view the announcements for each of the cluster ports.
Syslog Message
The cluster ports with "link" reported as "up" are neither receiving CDP nor LLDP neighbor announcements.
(None).
clus.net.switchlessInv
Severity
NOTICE
This message occurs when the "switchless-cluster" option is disabled, but one or more cluster ports are directly wired to a cluster port on another node. This could result in packet loss across the cluster network, causing file operations to fail as well as loss of quorum.
Corrective Action
Use the "network options switchless-cluster modify" command to enable support for switchless clusters.
Syslog Message
One or more cluster ports are directly wired to a cluster port on another node, but the "switchless-cluster" option is not enabled.
(None).
clus.net.switchlessMismatch
Severity
NOTICE
This message occurs when the "switchless-cluster" option is enabled, but all of the cluster ports are wired to a switch. This configuration will negatively impact the performance of the cluster network.
Corrective Action
Use the "network options switchless-cluster modify" command to disable support for switchless clusters.
Syslog Message
All of the cluster ports are wired to a switch, but the "switchless-cluster" option is enabled.
(None).
