ONTAP EMS reference
disk.encryptnosupport events
disk.encryptNoSupport
Severity
ALERT
This message occurs when ONTAP® software detects one or more FIPS-certified self-encrypting drives, but the environment variable 'bootarg.storageencryption.support' is not present or is set to "false" to indicate that FIPS-certified drives are not supported.
Corrective Action
Remove all FIPS-certified drives.
Syslog Message
Detected FIPS-certified encrypting drive %s, but FIPS drives are not supported on this node. %d of %d disks checked are FIPS-certified.
disk (STRING): Name of a FIPS-certified drive.
FIPS_disks (INT): Number of FIPS-certified drives detected.
disk_count (INT): Total number of drives checked. For a high-availability pair, this might be fewer than the total number of drives.
