      fabriclink.metadata events
fabriclink.metadata.too.long
- Severity
ERROR
 - Description
This message occurs when object replication encounters metadata key-value pairs that are too long when replicating an object from a remote object store. The object will be replicated without the metadata key-value pairs that are too long.
 - Corrective Action
Refer to the sktrace.log file for additional details about the objects that are replicated without some or all metadata. Reduce the size of individual metadata key-value pairs for objects if they should be replicated with the object.
 - Syslog Message
There are objects with metadata key-value pairs that are too long to be replicated.
 - Parameters
(None).
