ONTAP EMS reference
fabriclink.metadata events
fabriclink.metadata EMS events occur when object replication encounters metadata key-value pairs that are too long when replicating an object from a remote object store.
Severity
ERROR
This message occurs when object replication encounters metadata key-value pairs that are too long when replicating an object from a remote object store. The object will be replicated without the metadata key-value pairs that are too long.
Corrective Action
Refer to the sktrace.log file for additional details about the objects that are replicated without some or all metadata. Reduce the size of individual metadata key-value pairs for objects if they should be replicated with the object.
Syslog Message
There are objects with metadata key-value pairs that are too long to be replicated.
(None).
