ONTAP EMS reference
fc.bridge events
fc.bridge.fc.port.alert
Severity
ALERT
This message occurs when an FC port goes offline.
Corrective Action
Check cables, SFPs, and connected devices. If the port is intentionally unused, use the Fibre Channel bridge CLI to disable it.
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s FC Port FC_PORT%d offline. %s
bridgeType (STRING): Type of the FC-to-SAS bridge.
bridgeName (STRING): Name of the FC-to-SAS bridge.
bridgeSerialNum (STRING): Serial number of the FC-to-SAS bridge.
bridgeWWN (STRING): World-Wide Name (WWN) of the FC-to-SAS bridge.
bridgePort (INT): Port reported by the FC-to-SAS bridge.
addlInfo (STRING): Additional information about the alert being generated, if available.
fc.bridge.fc.port.notice
Severity
NOTICE
This message occurs when an FC port on the identified bridge comes online.
Corrective Action
(None).
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s FC Port FC_PORT%d connected. %s
fc.bridge.power.alert
Severity
ALERT
This message occurs when an FC-to-SAS bridge power supply fails.
Corrective Action
Check input power and cable. If the problem persists, replace the power supply.
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s Power Supply %s has failed. %s
bridgePowerSupply (STRING): Power supply reported by the FC-to-SAS bridge.
fc.bridge.power.notice
Severity
NOTICE
This message occurs when an FC-to-SAS bridge power supply returns to normal operation.
Corrective Action
(None).
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s Power supply %s operating normally. %s
bridgePowerSupply (STRING): Port reported by the FC-to-SAS bridge.
fc.bridge.sas.phy.alert
Severity
ALERT
This message occurs when a SAS port PHY goes offline.
Corrective Action
Check Mini-SAS HD connector, cables, and connected equipment.
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port %d Phy %d offline. %s
bridgePhy (INT): SAS port Phy reported by the FC-to-SAS bridge.
fc.bridge.sas.phy.notice
Severity
NOTICE
This message occurs when a SAS port PHY on a bridge comes online.
Corrective Action
(None).
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS port %d Phy %d online. %s
bridgePhy (INT): Phy reported by the FC—​to-SAS bridge.
fc.bridge.sas.port.alert
Severity
ALERT
This message occurs when an SAS port goes offline.
Corrective Action
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port SAS_PORT%d offline. %s
fc.bridge.sas.port.notice
Severity
NOTICE
This message occurs when an SAS port on the identified bridge comes online.
Corrective Action
(None).
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s SAS Port SAS_PORT%d connected. %s
fc.bridge.temp.alert
Severity
ALERT
This message occurs when an FC-to-SAS bridge reaches a elevated temperature threshold. The bridge will continue to operate, but action should be taken to reduce the temperature.
Corrective Action
The bridge is experiencing an elevated temperature, which indicates a loss of cooling airflow. Check cooling airflow, fan operation, and ambient temperature, and take action to reduce the FC-to-SAS bridge operating temperature. If this is not done and the temperature continues to rise, the FC-to-SAS bridge will shut down when the critical temperature threshold is reached.
Syslog Message
FC-to-SAS %s bridge with name: %s S/N: %s WWN: %s is operating at elevated temperature (%d C). %s
bridgeTemp (INT): Temperature reported by the FC-to-SAS bridge.
fc.bridge.temp.emergency
Severity
EMERGENCY
This message occurs when an FC-to-SAS bridge reaches a critical temperature threshold. The bridge will shut down to protect the hardware.
Corrective Action
Take immediate action to reduce the operating temperature of the FC-to-SAS bridge to avoid hardware damage. Check cooling airflow, fan operation, and ambient temperature. The FC-to-SAS bridge will shut down when this condition is reached, and will not operate until the temperature is reduced.
Syslog Message
FC-to-SAS %s bridge with name: %s S/N: %s WWN:%s has reached critical temperature (%d C) and will soon shut down. %s
fc.bridge.temp.notice
Severity
NOTICE
This message occurs when an FC-to-SAS bridge returns to a normal operating temperature. No action needs to be taken, because the FC-to-SAS bridge temperature has returned to normal levels.
Corrective Action
(None).
Syslog Message
FC-to-SAS %s bridge %s S/N: %s WWN: %s temperature has returned to normal (%d C). %s
fc.bridge.throughput.alert
Severity
ALERT
This message occurs when an FC-to-SAS bridge experiences degraded throughput.
Corrective Action
Contact NetApp technical support.
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s is experiencing degraded throughput. %s
fc.bridge.throughput.notice
Severity
NOTICE
This message occurs when an FC-to-SAS bridge recovers from degraded throughput.
Corrective Action
(None).
Syslog Message
Fibre Channel %s Bridge %s S/N: %s WWN: %s throughput is normal. %s
