ONTAP EMS reference
flexcache.attrib events
flexcache.attrib.sync.failed
Severity
ALERT
This message occurs when when syncing properties between an origin of a FlexCache volume and its FlexCache volume fails, and due to which FlexCache volume may not be able to proceed with accurate data.
Corrective Action
Use the "volume flexcache sync-properties" command on the cluster hosting the FlexCache volume to sync the origin volume properties with the FlexCache volume.
Syslog Message
Failed to sync the FlexCache configuration for cluster %s in Vserver %s hosting FlexCache volume %s.
cacheCluster (STRING): Name of the cluster hosting the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the FlexCache volume.
cacheVolName (STRING): Name of FlexCache volume for which sync failed.
flexcache.attrib.sync.passed
Severity
NOTICE
This message occurs when origin of a FlexCache volume properties sync succeeds for all connected FlexCache volumes.
Corrective Action
(None).
Syslog Message
Sync of origin of a FlexCache volume %s in Vserver %s succeeded for all connected FlexCache volumes.
originVolName (STRING): Origin of a FlexCache volume.
originVserver (STRING): Name of the Vserver hosting the origin of a FlexCache volume.
flexcache.attrib.sync.warn
Severity
NOTICE
This message occurs when syncing properties between an origin of a FlexCache volume and its FlexCache volume fails, and the sync operation will be retried.
Corrective Action
Syslog Message
Failed to sync the FlexCache configuration for cluster %s in Vserver %s hosting FlexCache volume %s. Operation will be retried.
