ONTAP EMS reference
flexcache.attrib events
flexcache.attrib EMS events occur when ONTAP encounters issues associated with FlexCache volume property synchronization.
flexcache.attrib.sync.failed
Severity
ALERT
This message occurs when syncing properties between an origin of a FlexCache volume and its FlexCache volume fails, and due to which FlexCache volume may not be able to proceed with accurate data.
Corrective Action
Use the "volume flexcache sync-properties" command on the cluster hosting the FlexCache volume to sync the origin volume properties with the FlexCache volume.
Syslog Message
Failed to sync the FlexCache configuration for cluster %s in Vserver %s hosting FlexCache volume %s.
cacheCluster (STRING): Name of the cluster hosting the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the FlexCache volume.
cacheVolName (STRING): Name of FlexCache volume for which sync failed.
flexcache.attrib.sync.passed
Severity
NOTICE
This message occurs when origin of a FlexCache volume properties sync succeeds for all connected FlexCache volumes.
Corrective Action
(None).
Syslog Message
Sync of origin of a FlexCache volume %s in Vserver %s succeeded for all connected FlexCache volumes.
originVolName (STRING): Origin of a FlexCache volume.
originVserver (STRING): Name of the Vserver hosting the origin of a FlexCache volume.
flexcache.attrib.sync.warn
Severity
NOTICE
This message occurs when syncing properties between an origin of a FlexCache volume and its FlexCache volume fails, and the sync operation will be retried.
Corrective Action
Syslog Message
Failed to sync the FlexCache configuration for cluster %s in Vserver %s hosting FlexCache volume %s. Operation will be retried.
