ONTAP EMS reference
ktls.cnxnhandshakelimit events
ktls.cnxnhandshakelimit EMS events occur when the concurrent TLS connection handshake limit is reached.
ktls.cnxnHandshakeLimit
Severity
NOTICE
This message occurs when the concurrent TLS connection handshake limit is reached. Any new TLS connection request will fail and an error status will be returned.
Corrective Action
Reduce the encrypted connection load on ONTAP to avoid reaching the maximum concurrent TLS handshake limit.
Syslog Message
ONTAP reached the maximum limit of %d concurrent TLS connection handshakes. If this limit is reached, subsequent TLS connections will fail.
maxTLSConnHandles (INT): Maximum number of concurrent TLS connection handshakes.
