ktls.failed events
ktls.failed EMS events occur when several successive Transport Layer Security (TLS) connections with a remote system have failed.
ktls.failed
- Severity
NOTICE
- Description
This message occurs when several successive Transport Layer Security (TLS) connections with a remote system have failed.
- Corrective Action
Corrective actions will necessarily depend on what condition is being reported.
- Syslog Message
"The TLS connections have failed several times with remote host '%s' in IPspace '%s', for which the latest reason given is: %s."
- Parameters
peer (STRING): Network address of the remote peer.
ipsname (STRING): IPspace within which the network address is defined.
reason (STRING): Reason for failure.
