ONTAP EMS reference
lmgr.persistent events
lmgr.persistent EMS events occur when ONTAP encounters issues associated with persistent open lock count limits.
lmgr.persistent.file.open.limit.hit
Severity
NOTICE
This message is triggered when the persistent open lock count for a single file reaches its maximum supported limit.
Corrective Action
Use the "volume file show-inode" command with the file ID and volume name information to find the file path. From the diagnostic privilege level, execute "lmgr test show_ca_locks_count <file_path>" to inspect the persistent open lock count for the file. If necessary, close unused opens to reduce the count to the maximum limit of persistent open locks per file.
Syslog Message
The file with id %u on volume '%s' (DSID %llu) has hit its maximum persistent open lock count, fully utilizing the supported limit of %u.
file_id (INT): File inode number.
vol_name (STRING): Name of the volume.
vol_dsid (LONGINT): Data set identifier (DSID) of the volume.
locks_limit (INT): Maximum supported persistent open locks count for a file.
lmgr.persistent.file.open.limit.warn
Severity
NOTICE
This message is triggered when the persistent open lock count for a single file reaches 80% its maximum supported limit.
Corrective Action
Syslog Message
The persistent open lock count for file with id %u on volume '%s' (DSID %llu) has reached %u, constituting 80 percent of its maximum supported limit of %u.
locks_total (INT): Number of persistent open lock count for file.
lmgr.persistent.open.limit.hit
Severity
NOTICE
This message occurs when the number of persistent open lock count reaches the maximum supported limit.
Corrective Action
Run the "vserver locks show-mirrored-open-count -detailed" command to check the persisted open lock count and try closing the unused files to bring this count down to the currently supported maximum persistent open locks.
Syslog Message
The number of persisted open locks count %u has reached the limit %u.
locks_total (INT): Number of persisted open locks.
locks_limit (INT): Maximum supported persisted open locks.
