ONTAP EMS reference
mcc.fabricpool events
mcc.fabricpool.license.absent
Severity
ERROR
This message occurs when a FabricPool license exists on only one of the two sites of a MetroCluster(tm) configuration.
Corrective Action
Install a FabricPool license on the cluster that is missing the license.
Syslog Message
The FabricPool license is installed on only one site of this MetroCluster configuration. The license is missing on cluster %s (ID: %s).
cluster_name (STRING): Name of the cluster which is missing the license.
cluster_uuid (STRING): UUID of the cluster.
mcc.fabricpool.license.diff
Severity
ERROR
This message occurs when the FabricPool license capacity or term limits are different for the two sites of a MetroCluster(tm) configuration.
Corrective Action
Install a new license on one of the clusters so that the license limits match.
Syslog Message
The FabricPool license limits are different for the two sites of this MetroCluster configuration. The license limits are %s and %s on site %s and %s and %s on site %s.
local_license_limit (STRING): License capacity limit from the local cluster.
local_term_limit (STRING): License term limit from the local cluster.
local_cluster_name (STRING): Name of the local cluster.
remote_license_limit (STRING): License capacity limit from the remote cluster.
remote_term_limit (STRING): License term limit from the remote cluster.
remote_cluster_name (STRING): Name of the remote cluster.
mcc.fabricpool.mirror.missing
Severity
ALERT
This message occurs when a FabricPool in a MetroCluster configuration does not have a mirror object store attached.
Corrective Action
Use the "storage aggregate object-store mirror" command to add a mirror object store to the FabricPool.
Syslog Message
FabricPool: "%s" UUID: "%s" in a MetroCluster configuration does not have synchronous data protection enabled because the mirror object store is missing.
aggr (STRING): Name of the FabricPool.
UUID (STRING): UUID of the FabricPool.
