ONTAP EMS reference
mgmt.cifsshare events
mgmt.cifsshare.duplicatesid
Severity
NOTICE
This message occurs when a network client attempts to set a CIFS share's discretionary access control list (DACL) to a list where any security descriptor (SID) appears in more than one access control entry (ACE). The operation is failed and no changes are made to the share's DACL.
Corrective Action
(None).
Syslog Message
Duplicate SID not supported in CIFS share DACL %s
vservername (STRING): Name of the Vserver.
cifssharename (STRING): Name of the CIFS share.
sid (STRING): Textual SID.
mgmt.cifsshare.failure
Severity
ERROR
This message occurs when configuration of a CIFS share fails; CIFS access to the share might not be available.
Corrective Action
Check the reason for the error and take action accordingly.
Syslog Message
Failed to configure CIFS share. Error: %s.
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
cifsservername (STRING): Name of the cifs server.
cifssharename (STRING): Name of the cifs share.
mgmt.cifsshare.success
Severity
INFORMATIONAL
This message occurs when a CIFS share is successfully configured after a failure.
Corrective Action
(None).
Syslog Message
(None).
