ONTAP EMS reference
migrate.root events
migrate.root.completed
Severity
NOTICE
This message occurs when the migration of a root aggregate has completed successfully.
Corrective Action
(None).
Syslog Message
Root aggregate migration completed successfully on node %s.
node (STRING): Name of the node that completed the migration.
migrate.root.failed
Severity
ERROR
This message occurs when the migration of a root aggregate has failed.
Corrective Action
Run the "system node run -node nodename -command aggr status" command to determine if the target aggregate named "new_root" has been created. If not, address the error condition and attempt the "system node migrate-root" command again. If the new aggregate exists, contact technical support to complete the operation.
Syslog Message
Root aggregate migration failed on node %s. Reason: %s.
node (STRING): Name of the node that failed to complete the migration.
reason (STRING): Reason that the migrate operation failed.
migrate.root.started
Severity
NOTICE
This message occurs when the user initiates an attempt to move the root aggregate to a different set of disks on a node.
Corrective Action
(None).
Syslog Message
Root aggregate migration started on node %s.
node (STRING): Name of the node.
