ONTAP EMS reference
monitor.cluster events
monitor.cluster EMS events occur when ONTAP encounters issues associated with cluster space utilization.
monitor.cluster.full
Severity
ALERT
This message occurs when the cluster is full after consuming space beyond the threshold value.
Corrective Action
Create space by increasing the cluster size, or by deleting data or deleting snapshots.
Syslog Message
Physical space used by the cluster (%s%%) exceeds the full threshold (%d%%).
percent_full (STRING): Physical used space of the cluster, as a percent.
percent_threshold (INT): Threshold percent of physical used space which triggers the cluster full condition.
monitor.cluster.nearlyFull
Severity
ERROR
This message occurs when the cluster is nearly full after consuming space beyond the threshold value.
Corrective Action
Syslog Message
Physical used space by the cluster (%s%%) exceeds the nearly full threshold (%d%%).
percent_threshold (INT): Threshold percent of physical used space which triggers the cluster nearly full condition.
monitor.cluster.ok
Severity
NOTICE
This message occurs when the previously reported cluster full condition is fixed.
Corrective Action
(None).
Syslog Message
Cluster is no longer full. Physical space used by the cluster (%s%%).
monitor.cluster.overalloc
Severity
EMERGENCY
This message occurs when the cluster is over allocated after consuming space beyond cluster size.
Corrective Action
Syslog Message
Physical space used by the cluster (%s%%) exceeds maximum space in the cluster.
