monitor.cluster events
monitor.cluster EMS events occur when ONTAP encounters issues associated with cluster space utilization.
monitor.cluster.full
- Severity
ALERT
- Description
This message occurs when the cluster is full after consuming space beyond the threshold value.
- Corrective Action
Create space by increasing the cluster size, or by deleting data or deleting snapshots.
- Syslog Message
Physical space used by the cluster (%s%%) exceeds the full threshold (%d%%).
- Parameters
percent_full (STRING): Physical used space of the cluster, as a percent.
percent_threshold (INT): Threshold percent of physical used space which triggers the cluster full condition.
monitor.cluster.nearlyFull
- Severity
ERROR
- Description
This message occurs when the cluster is nearly full after consuming space beyond the threshold value.
- Corrective Action
- Syslog Message
Physical used space by the cluster (%s%%) exceeds the nearly full threshold (%d%%).
- Parameters
percent_threshold (INT): Threshold percent of physical used space which triggers the cluster nearly full condition.
monitor.cluster.ok
- Severity
NOTICE
- Description
This message occurs when the previously reported cluster full condition is fixed.
- Corrective Action
(None).
- Syslog Message
Cluster is no longer full. Physical space used by the cluster (%s%%).
- Parameters
monitor.cluster.overalloc
- Severity
EMERGENCY
- Description
This message occurs when the cluster is over allocated after consuming space beyond cluster size.
- Corrective Action
- Syslog Message
Physical space used by the cluster (%s%%) exceeds maximum space in the cluster.
- Parameters
