ONTAP EMS reference
mw.iron events
mw.iron.mount.idlog.purge
Severity
INFORMATIONAL
This message is used to notify idlog purge at mount after 7 consecutive unsuccessful iron runs.
Corrective Action
(None).
Syslog Message
Volume[%s] : Wafliron mount performance may be significantly impacted, because idlog purge is triggered after[%d] unsuccessful iron runs.
vol (STRING): Name of the volume.
generation (INT): Iron generation number.
