nblade.cifsshrconnectfailed events
Nblade.cifsShrConnectFailed
- Severity
ERROR
 - Description
This message occurs when the network blade cannot connect to the path specified in the CIFS share.
 - Corrective Action
Verify that the CIFS share path is valid and that the volume it belongs to is accessible.
 - Syslog Message
Vserver name: %s, Vserver ID: %d, error description: %s, error code: %d, share name: %s, Windows user name: %s, UNIX user name: %s, server IP address: %s, client IP address: %s.
 - Parameters
vserverName (STRING): Name for the Vserver associated with this operation.
vserverId (INT): Identifier for the Vserver associated with this operation.
errorDescription (STRING): Description of the error for the CIFS share connection failure.
errorCode (INT): Error code that describes the reason for the CIFS share connection failure.
shareName (STRING): Name of the share to which the connection attempt failed.
domainWinUserName (STRING): Windows domain\user that is attempting to connect to the share.
unixUserName (STRING): UNIX user name.
serverIp (STRING): IP address of the server.
clientIp (STRING): IP address of the client.
