ONTAP EMS reference
nblade.tlsconfigerror events
nblade.tlsconfigerror EMS events occur when the client is trying to use NFS over TLS (Transport Layer Security), but it is disabled on the NFS server side.
Nblade.TLSConfigError
Severity
ERROR
This message occurs when the client is trying to use NFS over TLS (Transport Layer Security), but it is disabled on the NFS server side.
Corrective Action
Enable the configuration by running "nfs tls interface enable" command.
Syslog Message
Failed to create NFS over TLS (Transport Layer Security) connection from client IP address:"%s", because NFS over TLS configuration not found for SVM:"%s", LIF:"%s".
clientIpAddress (STRING): Client IP address.
vsName (STRING): Storage virtual machine (SVM) name.
lifIpAddress (STRING): LIF IP address of NFS server.
