ONTAP EMS reference
netif.fwhotplugfailed events
netif.fwHotplugFailed
Severity
NOTICE
This message occurs when there is an error while performing a device hotplug after the network interface firmware update is completed. When this happens, the controller reboots to resolve the error.
Corrective Action
(None).
Syslog Message
Hotplug %s slot: %s at PCI: %s failed. The controller will reboot.
action (STRING): Insert or remove action of the device hotplug.
slot_num (STRING): Slot number of the network interface card.
location (STRING): PCI location of the network interface.
