netif.fwhotplugfailed events
netif.fwhotplugfailed EMS events occur when there is an error while performing a device hotplug after the network interface firmware update is completed.
netif.fwHotplugFailed
- Severity
NOTICE
- Description
This message occurs when there is an error while performing a device hotplug after the network interface firmware update is completed. When this happens, the controller reboots to resolve the error.
- Corrective Action
(None).
- Syslog Message
Hotplug %s slot: %s at PCI: %s failed. The controller will reboot.
- Parameters
action (STRING): Insert or remove action of the device hotplug.
slot_num (STRING): Slot number of the network interface card.
location (STRING): PCI location of the network interface.
