ONTAP EMS reference
oauth2.localroles events
oauth2.localroles.unauth
Severity
ERROR
This message occurs when an authentication fails when the "use-local-roles-if-present" setting is set to "true", but the user information does not exist in ONTAP, or the scope information within the access token does not grant sufficient access in ONTAP.
Corrective Action
Add a local user entry using the "security login create" command, or include the relevant scope information in the access token.
Syslog Message
Authentication of requested user "%s" in SVM "%s" failed because the "use-local-roles-if-present" setting is set to "true"; however, the user information does not exist in ONTAP, or the scope information within the access token does not grant sufficient access in ONTAP.
user (STRING): User for whom authentication failed.
vserver (STRING): SVM to which the user belongs.
