oauth2.localroles events
oauth2.localroles EMS events occur when an authentication fails when the "use-local-roles-if-present" setting is set to "true", but the user information does not exist in ONTAP, or the scope information within the access token does not grant sufficient access in ONTAP.
oauth2.localroles.unauth
- Severity
ERROR
- Description
This message occurs when an authentication fails when the "use-local-roles-if-present" setting is set to "true", but the user information does not exist in ONTAP, or the scope information within the access token does not grant sufficient access in ONTAP.
- Corrective Action
Add a local user entry using the "security login create" command, or include the relevant scope information in the access token.
- Syslog Message
Authentication of requested user "%s" in SVM "%s" failed because the "use-local-roles-if-present" setting is set to "true"; however, the user information does not exist in ONTAP, or the scope information within the access token does not grant sufficient access in ONTAP.
- Parameters
user (STRING): User for whom authentication failed.
vserver (STRING): SVM to which the user belongs.
