ONTAP EMS reference
probedone.inquiry events
probedone.inquiry.failed
Severity
ERROR
This message occurs when the inquiry data fails the comparison at the domain validation (DV) step.
Corrective Action
Check whether the device is connected correctly.
Syslog Message
In path %s, inquiry data fails comparison at the domain validation DV%d step of protocol type %d.
path (STRING): Device path.
inquirydata (INT): Comparison between the inquiry data failure and the domain validation, and whether the probe inquiry domain validation is type 1 or 2.
protocol_type (INT): Protocol type.
