ONTAP EMS reference
raid.fm events
raid.fm.disasterSummary
Severity
ERROR
This event contains summary information for the disaster takeover. It is only generated if a disaster takeover occurs.
Corrective Action
(None).
Syslog Message
RAID disaster takeover summary: number of partner volumes and aggregates=%d, number of rewrite-fsid partner volumes and aggregates=%d, number of out-of-date partner volumes and aggregates=%d, number of ignored partner volumes and aggregates=%d, number of local volumes and aggregates=%d, number of out-of-date local volumes and aggregates=%d
nPvols (INT): The number of partner volumes involved in the takeover
nRwPvols (INT): The number of rewrite-fsid partner volumes
nOodPvols (INT): The number of out-of-date partner volumes
nIgnPvols (INT): The number of ignored partner volumes
nLvols (INT): The number of local volumes involved in the takeover
nOodLvols (INT): The number of out-of-date local volumes
raid.fm.fixedMixedOwnership
Severity
NOTICE
This message occurs when assimilation detects that an aggregate contains disks with multiple current owner IDs and fixes the ownership issue.
Corrective Action
(None).
Syslog Message
Aggregate %s was detected to have disks with mixed current owner IDs and the ownership has been fixed.
aggregate (STRING): Name of the aggregate that contained disks with mixed owner IDs.
disk_count (INT): Number of disks that had their current owner ID fixed.
current_owner_id (INT): NVRAM system ID of the aggregate's current owner.
raid.fm.leftBehindAggr
Severity
NOTICE
This message occurs when an aggregate is not returned to its original owner in a giveback operation.
Corrective Action
Run the 'storage failover giveback' command to return the aggregate to its original owner.
Syslog Message
Aggregate %s was left behind during giveback.
aggregate (STRING): Name of the aggregate that was left behind.
aggregate_uuid (STRING): Universal Unique Identifier (UUID) of the aggregate.
home_owner_id (LONGINT): NVRAM system ID of the aggregate's home owner.
current_owner_id (LONGINT): NVRAM system ID of the aggregate's current owner.
raid.fm.replayFail
Severity
NOTICE
This message occurs when RAID replay fails for partner aggregates during takeover. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
RAID takeover: RAID replay failed. Status: %d.
status (INT): Replay failure status code.
raid.fm.takeoverFail
Severity
ALERT
This message occurs when a high-availability (HA) takeover attempt fails due to an assimilation error.
Corrective Action
If partner aggregates are failing to assimilate on the surviving node of the HA pair, contact technical support for assistance with bringing these aggregates online.
Syslog Message
RAID takeover failed: %s.
reason (STRING): Reason the takeover failed.
raid.fm.volDisasterBadState
Severity
ERROR
This message occurs when the system cannot split an out-of-date volume due to a bad volume state.
Corrective Action
(None).
Syslog Message
Partner volume %s identity unaltered during HA disaster takeover: bad state %s. Clients might see stale data.
vol (STRING): Name of the aggregate.
state (STRING): Aggregate state.
raid.fm.volDisasterFail
Severity
ERROR
This message occurs when the system encounters an error during a high availability (HA) disaster takeover.
Corrective Action
(None).
Syslog Message
Partner volume %s HA disaster takeover error (%s): %s. Clients will not be able to access this volume.
type (STRING): Type of error
reason (STRING): Internal reason code
raid.fm.volDisasterIgnore
Severity
ERROR
This message occurs when the system ignores a volume during a high availability (HA) disaster takeover.
Corrective Action
(None).
Syslog Message
Partner volume %s identity unaltered during HA takeover: %s. Clients might see stale data.
reason (STRING): Reason for ignoring the volume
code (INT): Internal code
raid.fm.volDisasterWarn
Severity
ERROR
This message occurs when the system encounters a nonfatal error during a high availability (HA) disaster takeover
Corrective Action
(None).
Syslog Message
Partner volume %s HA disaster takeover warning (%s): %s Volume takeover might be incomplete and clients might see stale data.
raid.fm.volFsidRewrite
Severity
ERROR
This message occurs when the system rewrites a volume's or aggregate's canceling giveback high availability (HA) disaster takeover.
Corrective Action
Remount the clients of the volume.
Syslog Message
Partner %s %s FSID was rewritten during HA disaster takeover. Clients must be remounted.
vol_type (STRING): Volume type.
oldFsid (INT): Old fsid
newFsid (INT): New fsid
raid.fm.volFsidRewriteOod
Severity
ERROR
This message occurs when the system rewrites a volume's File System ID (FSID) during a high availability (HA) disaster takeover with an out-of-date volume.
Corrective Action
Syslog Message
Partner volume %s FSID was rewritten during HA disaster takeover. Clients must be remounted.
