ONTAP EMS reference
raid.foreign events
raid.foreign EMS events occur when a disk is found to have a different storage pod uuid than what this node is allowed to access.
raid.foreign.disk.failed
Severity
ERROR
This message occurs when a disk is found to have a different storage pod uuid than what this node is allowed to access.
Corrective Action
This disk has been marked as foreign disk. Unfail the failed disk using command 'disk unfail' with '-spare true' option and mark it as a spare or contact NetApp technical support
Syslog Message
Disk "%s" has failed as the uuid on the RAID label "%s" does not match with stamped uuid "%s"
disk_name (STRING): Name of the disk.
label_uuid (STRING): Actual Storage Pod UUID on the RAID label.
cached_uuid (STRING): Storage Pod UUID stamped on the disk in terms of ownership.
