raid.foreign events
raid.foreign.disk.failed
- Severity
ERROR
- Description
This message occurs when a disk is found to have a different storage pod uuid than what this node is allowed to access.
- Corrective Action
This disk has been marked as foreign disk. Unfail the failed disk using command 'disk unfail' with '-spare true' option and mark it as a spare or contact NetApp technical support
- Syslog Message
Disk "%s" has failed as the uuid on the RAID label "%s" does not match with stamped uuid "%s"
- Parameters
disk_name (STRING): Name of the disk.
label_uuid (STRING): Actual Storage Pod UUID on the RAID label.
cached_uuid (STRING): Storage Pod UUID stamped on the disk in terms of ownership.
